[GRASS-user] Region Definition in GRASS
Fri Feb 5 13:50:14 EST 2010
Pedro Roma wrote:
> Ok but for instance. If my region is defined with a Spatial Resolution of
> 1kilometer and, if I do some r.mapcalc with two LANDSAT images, the output
> image will have which one of the resolutions? the Region or the 2 landsat
> images?
The region.
Most raster modules (including r.mapcalc) generate maps with the
bounds and resolution of the current region. Input maps are cropped,
padded and/or resampled to the current region, so all processing
within the module takes place on the grid defined by the current
region.
The main exceptions are the r.in.* modules, which import files
cell-for-cell, using the bounds specified in the file's metadata if
present. The current region is ignored.
Modules which perform their own resampling (e.g. r.resamp.*, r.proj)
create output maps according to the current region but read their
input maps without cropping or resampling.
