[GRASS-user] export of a GRASS voxel to .VTK induces deformation
    yepri
    a.yepri at gmail.com
    Sun Feb  7 06:53:23 EST 2010
Here are the commands I used in GRASS 6.4 RC5 (under OSX Leopard) :
# computation of a 3d raster with z values from z() function
r3.mapcalc Z='z()'
# export to VTK format with top (the srtm DEM) and bottom (a flat surface)
r3.out.vtk Z output=./Z_3dg.vtk -s top=srtm30 bottom=bottom --overwrite
Instead of cutting into the GRASS raster 3d, the r3.out.vtk command deforms
the cells, so that computed z() isosurfaces are not horizontal (see image
grid_inversed_deformed_z below).
I expected top and bottom function of r3.out.vtk to cut into the model,
instead of applying deformation to fit the top and bottom. Am I right ?
http://n2.nabble.com/file/n4528866/grid_inversed_deformed_z.png
thanks for your reply,
cheers
View this message in context: http://n2.nabble.com/export-of-a-GRASS-voxel-to-VTK-induces-deformation-tp4528866p4528866.html
Sent from the Grass - Users mailing list archive at Nabble.com.
