[GRASS-user] Geometric Correction
Luis Lisboa
luislisboa1975 at gmail.com
Mon Feb 8 04:13:42 EST 2010
Ok I see
Are there any remains from the code that was stuck in GRASS 4/5?
On Thu, Feb 4, 2010 at 2:11 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Feb 4, 2010 at 2:06 PM, Luis Lisboa <luislisboa1975 at gmail.com>
> wrote:
> >> Relevant for you is this:
> >> - "implement/finish linewise ortho-rectification of satellite data"
> >> ...unfortunately stuck since GRASS 4/5...
> > Regarding this... According to Lillesand and Kiefer the idea is to
> correct
> > geometric distortions of the image.
> > For instance, the Georrectify module is not enough? or the i.rectify
> > function?
> It is not enough because it is made for aerial photos (central projection)
> while satellite data are line-wise scanners (so central projection only
> in one direction).
> >> It would be great to see the existing algorithms integrated.
> > Ok Since I will need to do some work on this, at the end I can contribute
> > with some code/functions
> great! happy hacking,
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100208/88a00d1b/attachment.html
