[GRASS-user] Region Definition in GRASS
Micha Silver
micha at arava.co.il
Mon Feb 8 12:49:37 EST 2010
Pedro Roma wrote:
> By the way. Instead of being setting everytime g.region xxxx -p can I
> save a region definition
As it says in the g.region manual:
save=name
Save current region settings in named region file
So:
g.region xxxx -p save=<your_region_name>
> and use it everytime? If so, how do I load region definition in a script?
Each time you start GRASS it begins with the region settings from the
previous session. You can go to any other saved region by:
g.region region=<your_region_name>
> Thanks
> Best regards
> Pedro
> On Fri, Feb 5, 2010 at 6:50 PM, Glynn Clements
> <glynn at gclements.plus.com <mailto:glynn at gclements.plus.com>> wrote:
> Pedro Roma wrote:
> > Ok but for instance. If my region is defined with a Spatial
> Resolution of
> > 1kilometer and, if I do some r.mapcalc with two LANDSAT images,
> the output
> > image will have which one of the resolutions? the Region or the
> 2 landsat
> > images?
> The region.
> Most raster modules (including r.mapcalc) generate maps with the
> bounds and resolution of the current region. Input maps are cropped,
> padded and/or resampled to the current region, so all processing
> within the module takes place on the grid defined by the current
> region.
> The main exceptions are the r.in.* modules, which import files
> cell-for-cell, using the bounds specified in the file's metadata if
> present. The current region is ignored.
> Modules which perform their own resampling (e.g. r.resamp.*, r.proj)
> create output maps according to the current region but read their
> input maps without cropping or resampling.
> Glynn Clements <glynn at gclements.plus.com
> This mail was received via Mail-SeCure System.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
