On Wed, 10 Feb 2010, Markus Metz wrote: > r.terraflow stores elevation internally as floating-point single precision > which is more than enough if elevation is in meters or feet so you can > safely ignore the warning. Markus, Thank you. Perhaps that warning ought to be taken out of the code since it is not applicable. Rich
