[GRASS-user] r.watershed: Problems Using
Jarek Jasiewicz
jarekj at amu.edu.pl
Wed Feb 10 11:56:29 EST 2010
Rich Shepard pisze:
> On Wed, 10 Feb 2010, Markus Metz wrote:
>> The segment library failed to format a temporary file, it could not
>> write
>> to the file, but I don't know why. What does g.region -p say,
> Markus,
> GRASS 6.4.0svn (Oregon):/usr4/grassbase > g.region rast=aber5m res=5 -ap
> projection: 99 (Lambert Conformal Conic)
> zone: 0
> datum: nad83
> ellipsoid: grs80
> north: 1334420
> south: 1279150
> west: 769190
> east: 819260
> nsres: 5
> ewres: 5
> rows: 11054
> cols: 10014
> cells: 110694756
> That's 110 million cells; quite a large number.
not so large, I'd rather say moderate
>> ... and is there enough disk space free where your GISDBASE is?
> 18G free.
>>> Also, what guidelines does one apply to determine an appropriate
>>> threshold value for an exterior watershed basin?
>> That depends on your question, how detailed the extracted stream network
>> and basins should be. Given a minimum total catchment area (TCA) to
>> start
>> a stream, the threshold would be TCA / (nsres * ewres), translating
>> catchment area to number of cells.
> OK. Please explain 'exterior watershed basin' in the context of
> r.watershed.
it is the size (in cells number) of flow accumulation when r.watershed
starts delineate streams
> Thanks,
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
