[GRASS-user] Re: Defining Partial Drainage Basin
Micha Silver
micha at arava.co.il
Wed Feb 10 15:35:14 EST 2010
Rich Shepard wrote:
> On Wed, 10 Feb 2010, Micha Silver wrote:
>> A quick tip regarding r.water.outlet (you may have noticed this already)
>> The module creates a new raster covering the whole analysis region with
>> two possible values: 1 for all cells draining into the outlet, and 0
>> everywhere else. If you do r.to.vect straightaway, you?l get a vector
>> containing two polygons... I always run r.null setnull=0 on the
>> r.water.outlet result first. This insures that r.to.vect leaves you with
>> just the drainage area.
> Micha,
> I'm under a deadline to finish the current project, and nothing
> seems to
> be working correctly for me.
> I just ran r.water.outlet using the drainage (aspect) map created by
> r.watershed. The output is a yellow rectangle that the legend tells me
> represents '0'; that is, there're no cells in the calculated basin.
The r.water.outlet module takes two parameters: first is the drainage
*direction* raster, which I usually create first with r.watershed, like:
>r.watershed elev=dem drain=flow_dir accum=flow_acc basin=basin
stream=str thresh=xxxx
(At this stage you can go and make popcorn...)
Next I do r.thin on the streams raster, and convert the thinned raster
to a line vector:
>r.thin str out=str_thin
>r.to.vect -s str_thin out=streams feature=line
Now you need the pour point which, as others have made abundantly clear
( ;-) ), must be exactly on a stream line. So zoom in *very* close to
the flooded house, and identify the X-Y coords on the stream just below
the house.
Now try:
>r.water.outlet drain=flow_dir basin=house_catchment east=xxx north=yyy
And finally the above trick to get your final vector drainage basin with:
>r.null house_catchment setnull=0
and
>r.to.vect -s house_catchment out=house_catchment feature=area
Good luck...
> g.region -p reports:
> projection: 99 (Lambert Conformal Conic)
> zone: 0
> datum: nad83
> ellipsoid: grs80
> north: 1334420
> south: 1279150
> west: 769190
> east: 819260
> nsres: 10
> ewres: 10
> rows: 5527
> cols: 5007
> cells: 27673689
> The command line was:
> r.water.outlet drain=aber10m.drain basin=lockie e=795542.95
> n=1308323.52 --o
> I can send copies of aber10m.drain and lockie. It makes no sense to me
> that such a simple run fails to define the partial drainage basin. Any
> help
> or ideas you offer will be much appreciated.
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
