[GRASS-user] Re: Defining Partial Drainage Basin
Micha Silver
micha at arava.co.il
Thu Feb 11 02:04:49 EST 2010
On 02/11/2010 12:23 AM, Rich Shepard wrote:
> On Wed, 10 Feb 2010, Micha Silver wrote:
>> r.to.vect -s house_catchment out=house_catchment feature=area
> Micha,
> This process worked flawlessly ... once I corrected slightly off
> coordinates for the dam point. The last step I need is a way to calculate
> the areas of these two partial basins. They have no attribute information
> other than a category number.
How about:
> v.db.addcol house_basin col="area_sqm DOUBLE PRECISION"
>v.to.db house_basin opt=area col=area_sqm units=meters
> I tried v.overlay (intersecting the two maps) thinking that would
> calculate the area of the smaller (b) map from that of the larger (a)
> map.
> Doesn't work that way.
> My next try is to set the region to each of these partial basins,
> one-by-one, then calculate the area by multiplying the number of cells by
> 100 (10x10m resolution) and converting that to acres. This does not seem
> sufficiently precise to calculate the difference in drainage areas.
> r.stream.stats does not appear to help because that's working on the
> raster maps and not the vector versions.
> Isn't there a way to calculate areas of the vectors produced by the
> r.water.outlet-to-vector process?
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
http://www.surfaces.co.il/
Arava Development Co. +972-52-3665918
