[GRASS-user] Re: Defining Partial Drainage Basin
Jarek Jasiewicz
jarekj at amu.edu.pl
Thu Feb 11 02:58:05 EST 2010
Rich Shepard pisze:
> On Wed, 10 Feb 2010, Jarek Jasiewicz wrote:
>> http://grass.osgeo.org/wiki/R.stream.*
> Jarek,
> Will r.stream.stats calculate the basin area for the two
> sub-catchments?
> I see the input parameters as the raster maps for streams, flow
> direction,
> and DEM. Doesn't seem to calculate the areas of the two vector polygons.
> Thanks,
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
every cachmenet you can calculate using v.to.db what=area for polygons
