[GRASS-user] command echo?
Martin Wegmann
martin.wegmann at uni-wuerzburg.de
Mon Feb 15 09:07:56 EST 2010
Hello,
echo is just providing a text output on the screen.
hence
echo "process finished"
should give you:
"process finished"
on the CLI.
I attached a screenshot of a echo command inside a loop including the output.
Perhaps this helps.
regards, Martin
On Montag, 15. Februar 2010 15:01:13 Yvan Paillé wrote:
> Hello,
> I try to test the different command in the tutorial Grass Book but I
> have a problem with the "echo" command.
> I work on the geometry operation and for the exercice about the
> split/join segment extraction, I don't know how to use "echo" and his
> values. I'm working with the Grass 6.4 SVN with Msys.
> Thank you to guide me on a way.
> Yvan
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Dr. Martin Wegmann
University of Wuerzburg
Institute of Geography
Department of Remote Sensing
Remote Sensing and Ecosystem Research
Am Hubland
97074 Wuerzburg, Germany
German Aerospace Center (DLR)
German Remote Sensing Data Center (DFD)
Phone: +49-(0)931-31-83446
Fax: +49-(0)931-888-4961
Email: martin.wegmann at uni-wuerzburg.de
url: http://www.remote-sensing.uni-wuerzburg.de
url: http://www.dlr.de/caf
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20100215/cb35585d/grass_echo-0001.jpeg
