[GRASS-user] upgrade opensuse11.2 grass64
    Joop Goedbloed
    jlgoedbloed at hetnet.nl
    Tue Feb 16 04:25:00 EST 2010
Op 16-02-10 09:03, Otto Dassau schreef:
Hi Otto
The messages (so far as I'v tested) only appear when I'v doing something
like display, digitize etc. with vector maps.
> Hi,
> have you installed the grass package from the Application:Geo
> Repository? I updated those packages with a current svn snapshot from
> 6. Feb. 2010. As far as I tested, they work fine, except the known bug
> described here:
> http://trac.osgeo.org/grass/ticket/928
> You should make sure to update all packages and libraries on your
> system are uptodate. This can be done in YAST.
> hth
>  Otto
> Am Mon, 15 Feb 2010 20:20:48 -0800 (PST)
> schrieb Hamish <hamish_b op yahoo.com>:
>> Joop wrote:
>>> Last day I've upgrade to OpenSuSe 11.2 and reinstall
>>> Grass64 (6.4.0svn (2010))
>> how did you reinstall?
>> if building from source make sure to do "make distclean" and rebuild.
>>> Grass64 is runnig wel but when closing the gui I get a list of
>>> "errors!!??" like this below:
>>> GRASS 6.4.0svn (Venlo):~ > *** glibc detected *** wish:
>>> corrupted double-linked list: 0x081330a0
>>> /usr/lib/libtcl8.5.so[0xb75644e6]
>> something's broken with tcl/tk.
>> probably a program is built for an old version of the library but now
>> you have a new one in its place.
>> Hamish
>> grass-user mailing list
>> grass-user op lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
