[GRASS-user] Projection Units and Values Negatively Affect
	r.topidx Results
    Rich Shepard
    rshepard at appl-ecosys.com
    Thu Feb 18 12:15:46 EST 2010
On Wed, 17 Feb 2010, Markus Neteler wrote:
> I think that a change of the base unit of a location requires a new
> location and reprojection of the data. I may be wrong, though.
Markus/Hamish:
   I'm missing something critical here.
   I defined a new location (called oregonM) with the following projection
information and units:
PROJ_INFO:
name: Lambert Conformal Conic
proj: lcc
datum: nad83
ellps: grs80
lat_1: 43
lat_2: 45.5
lat_0: 41.45
lon_0: -120.5
x_0: 400000
y_0: 0
no_defs: defined
nadgrids: WO
PROJ_UNITS:
unit: meter
units: meters
meters: 1
   Using the wxPython GUI I import the source DEM specifying hdr.adf as the
ARC/GRID source. On the options tab I check "override projection information
and use location's projection" because that file has the units in feet:
[rshepard at salmo /usr4/Oregon]$ less dem10-nw/prj.adf
Projection    LAMBERT
Datum         NAD83
Zunits        NO
Units         3.2808400000
Spheroid      GRS1980
Xshift        0.0000000000
Yshift        0.0000000000
Parameters
  43  0  0.000 /* 1st standard parallel
  45 30  0.000 /* 2nd standard parallel
-120 30  0.000 /* central meridian
  41 45  0.000 /* latitude of projection's origin
400000.00000 /* false easting (meters)
0.00000 /* false northing (meters)
   However, after the file is imported and I run r.info on the map I see:
Type of Map:  raster               Number of Categories: 5729
Data Type:    CELL
Rows:         18724
Columns:      24657
Total Cells:  461677668
Projection: Lambert Conformal Conic
N: 1735231.43724681    S: 1120657.1324816   Res: 32.82281055
E: 952979.22944945    W: 143667.18968253   Res: 32.82281055
   I cannot seem to be able to convert from feet to meters during the import.
The command used was:
  r.in.gdal -o input="/usr4/Oregon/dem10-nw/hdr.adf" output="demNW10"
   What have I missed here?
Rich
