[GRASS-user] Projection Units and Values Negatively Affect
r.topidx Results
Glynn Clements
glynn at gclements.plus.com
Thu Feb 18 12:42:59 EST 2010
Rich Shepard wrote:
> I decided to try r.proj, and am told that there is no PERMANENT mapset in
> the source location. Is this a typographic error on my part?
> GRASS 6.4.0svn (oregonM):/usr4/grassbase > r.proj in=demNW
> loc=/usr4/grassbase/Oregon
The location= parameter should only specify the location *name*
(Oregon), not the path.
If you need to use a map from a different database, use the dbase=
option, i.e.
r.proj dbase=/usr4/grassbase loc=Oregon
