[GRASS-user] Projection Units and Values Negatively Affect
r.topidx Results
Rich Shepard
rshepard at appl-ecosys.com
Thu Feb 18 12:46:32 EST 2010
On Thu, 18 Feb 2010, Rich Shepard wrote:
> Is this a typographic error on my part?
Yes, it is. The location does not like the full path to be specified. So,
GRASS 6.4.0svn (oregonM):/usr4/grassbase > r.proj in=demNW loc=Oregon
mapset=PERMANENT out=demNW10 method=bilinear res=10.0 --o
Input Projection Parameters: +proj=lcc +lat_1=43 +lat_2=45.5 +lat_0=41.75
+lon_0=-120.5 +x_0=400000.00000000 +y_0=0 +no_defs +a=6378137
+rf=298.257222101 +nadgrids=/usr/local/grass-6.4.0svn/etc/nad/WO
Input Unit Factor: 0.3048
Output Projection Parameters: +proj=lcc +lat_1=43 +lat_2=45.5 +lat_0=41.45
+lon_0=-120.5 +x_0=400000 +y_0=0 +no_defs +a=6378137 +rf=298.257222101
Output Unit Factor: 1
ERROR: Input raster map is outside current region
When I look at the above output I see every parameter the same except for
the Input Unit Factor and Output Unit Factor. I don't know if that's for the height dimension or
the x-y coordinates.
Regardless of that factor, the other values are the same so why the error
message?
Rich
