[GRASS-user] upgrade opensuse11.2 grass64
Maris Nartiss maris.gis at gmail.com
Thu Feb 18 15:29:36 EST 2010
Hello,
I just after reading Your mails decided to hunt down this issue, as I
also had segfaults during exit on my Gentoo AMD64 box. Seems like
tcl/tk applications don't like calling exit during Destory event
(closing window). Fixed in 6.5. [1] Not backported to 6.4, as there
have been lot's of small fixes in gis.m for 6.5 to eliminate various
issues like PS label failures etc. and it's not that easy to change
code just to fix this segfault.
I don't have any voting power, still IMHO gis.m in 6.4 should be
synced with 6.5 version FTW.
Maris.
1.  http://trac.osgeo.org/grass/changeset/41099
2010/2/16, Otto Dassau <otto.dassau at gmx.de>:
> Hi Joop,
> On Tue, 16 Feb 2010 10:25:00 +0100
> Joop Goedbloed <jlgoedbloed at hetnet.nl> wrote:
>> Op 16-02-10 09:03, Otto Dassau schreef:
>> Hi Otto
>> The messages (so far as I'v tested) only appear when I'v doing something
>> like display, digitize etc. with vector maps.
> just tested with an opensuse 11.2 64bit. I opened the tcltk gui, loaded the
> spearfish map "streams", started the digitizing module in the tcltk gui,
> deleted a stream, closed/saved it, closed the tcltk gui and got following
> message.
> *** glibc detected *** gis.m: double free or corruption (out):
> 0x000000000103c6d0 ***
> Then I tried it a second time but did not get any errors anymore. And my
> message is different from the one you sent - strange. And apart from this
> message, everything works normal.
>> > With wxpython  gui there is no problem with tcl/tk gui grass64 is
>> > looking for tcl/tk 8.4 on my system there is version 8.5
>> > thats probable the problem.
> the grass package for opensuse 11.2 is compiled based on the standard tcl/tk
> 8.5. I guess something went wrong during the update, when your grass
> installtion is still looking for tcl/tk 8.4. Btw. from what opensuse did you
> upgrade, because 11.1 also uses tcl/tk 8.5 AFAIK.
> Regards,
>  Otto
>> > Hi,
>> > have you installed the grass package from the Application:Geo
>> > Repository? I updated those packages with a current svn snapshot from
>> > 6. Feb. 2010. As far as I tested, they work fine, except the known bug
>> > described here:
>> > http://trac.osgeo.org/grass/ticket/928
>> > You should make sure to update all packages and libraries on your
>> > system are uptodate. This can be done in YAST.
>> > hth
>> >  Otto
>> > Am Mon, 15 Feb 2010 20:20:48 -0800 (PST)
>> > schrieb Hamish <hamish_b at yahoo.com>:
>> >> Joop wrote:
>> >>> Last day I've upgrade to OpenSuSe 11.2 and reinstall
>> >>> Grass64 (6.4.0svn (2010))
>> >> how did you reinstall?
>> >> if building from source make sure to do "make distclean" and rebuild.
>> >>> Grass64 is runnig wel but when closing the gui I get a list of
>> >>> "errors!!??" like this below:
>> >>> GRASS 6.4.0svn (Venlo):~ > *** glibc detected *** wish:
>> >>> corrupted double-linked list: 0x081330a0
>> >>> /usr/lib/libtcl8.5.so[0xb75644e6]
>> >> something's broken with tcl/tk.
>> >> probably a program is built for an old version of the library but now
>> >> you have a new one in its place.
>> >> Hamish
>> >> _______________________________________________
>> >> grass-user mailing list
>> >> grass-user at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/grass-user
