[GRASS-user] Hydraulic Models With GRASS (Rich Shepard)
Adam Tokelove
TokeloveA at ap.aurecongroup.com
Thu Feb 18 16:54:14 EST 2010
Hi Rich
HEC-RAS will run under Wine, you will need to find, install and register
MFC40.dll - there is some guidance on it on the net.
The command line version of SWMM is a 10 minute exercise to compile on
Linux. The challenge would be presenting it with the correct output from
GRASS. Guidance is available from the EPA website as to what the run files
should look like.
I've got both (above) running under OpenSUSE.
Regards
Adam Tokelove
>> You can run HEC-RAS, 1-D flow model, freeware, only available for
windows
>> (Gods bless virtual machines) and then you can use r.inund.fluv (grass
>> addon) to spread the simulation result upon the DEM. Note that in order
to
>> use HEC-RAS you need measures of the river sections.
>Margherita,
> Hm-m-m. I have an old VMware guest with win98se that I can run on
>virtualbox. Don't know if the HEC series will run on that version of
>Microsoft.
>Rich
Disclaimer - http://www.aurecongroup.com/apac/disclaimer/
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100219/be7d978c/attachment.html
