[GRASS-user] Language of installed manual
Luigi Ponti
lponti at infinito.it
Fri Feb 19 12:29:57 EST 2010
On 19/02/2010 16:33, Martin Landa wrote:
> Hi,
> 2010/2/18 Glynn Clements <glynn at gclements.plus.com>:
>> The default locale is "C", which behaves the same as if no locale is
>> set (i.e. no call to setlocale()).
>> LC_ALL takes precedence over the individual LC_* variables and LANG,
>> so you may need to use:
>> export LC_ALL=C
> I have already tried to put `LC_ALL=C` to package.sh and recompile
> GRASS, but it didn't seem to help (module --interface-description
> still returns localized text).
> Martin
Thanks Martin. Just to detail further my report, in case it is useful
(sorry if redundant):
Installed last available WinGRASS-6.4.SVN-r41105-1-Setup.exe of 19 February.
If I do for example:
r.colors --interface-description
what is get is:
<?xml version="1.0" encoding="CP1252"?>
<!DOCTYPE task SYSTEM "grass-interface.dtd">
<task name="r.colors">
<description>
Creates/modifies the color table associated with a raster map layer.
</description>
<keywords>
raster, color table
</keywords>
<parameter name="map" type="string" required="no" multiple="no">
<description>
Nome della mappa raster in input
</description>
<keydesc>
<item order="1">name</item>
</keydesc>
<gisprompt age="old" element="cell" prompt="raster" />
<guisection>
Required
</guisection>
</parameter>
</task>
You can see there is English description plus some Italian text
depending on how far the translator got. It is the same text I get in
the g.parser GUI when invoking r.colors without arguments. I think this
is fine since I have an Italian locale. However, the HTML manual page of
r.colors is a partial Czech translation.
Kind regards,
Luigi
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100219/367dce2b/attachment.html
