SV: [GRASS-user] Help installing from
	http://trac.osgeo.org/grass/browser/grass-addons/
    Martin Album Ytre-Eide
    Martin.Album.Ytre-Eide at nrpa.no
    Mon Feb 22 06:00:54 EST 2010
Thank you for responding.
You are right. I installed grass with sudo and now tried as a normal user. It seems now that the permission and owner should be right.
However, despite this, I have got a new error message today:
 U   ps.output
Checked out revision 41157.
Compiling ps.output...
/usr/local/grass-6.5.svn/include/Make/Module.make:25: warning: overriding commands for target `install'
/usr/local/grass-6.5.svn/include/Make/Rules.make:82: warning: ignoring old commands for target `install'
make: *** No rule to make target `default', needed by `first'.  Stop.
ERROR: Compilation failed, sorry. Please check above error messages.
Any ideas ?
Martin
________________________________________
Fra: neteler.osgeo at gmail.com [neteler.osgeo at gmail.com] på vegne av Markus Neteler [neteler at osgeo.org]
Sendt: 19. februar 2010 16:10
Til: Martin Album Ytre-Eide
Kopi: grass-user at lists.osgeo.org
Emne: Re: [GRASS-user] Help installing from http://trac.osgeo.org/grass/browser/grass-addons/
On Fri, Feb 19, 2010 at 11:48 AM, Martin Album Ytre-Eide
<Martin.Album.Ytre-Eide at nrpa.no> wrote:
> Hello.
> I updated my GRASS 6.5 and now I get a different error:
> mkdir -p /usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/etc/paint/patterns/
> /usr/bin/install -c  -m 644 patterns/*.eps /usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/etc/paint/patterns/
> Installing ps.output...
> touch: cannot touch `/usr/local/grass-6.5.svn/g.extension.12845': Permission denied
> ERROR: Cannot write to </usr/local/grass-6.5.svn>, installation failed
> The permission should be alright, but the catalog /usr/local/grass-6.5.svn/g.extension.12845 does not seem to exist.
Please check the file permissions in
I suspect that it was installed with root permissions/sudo before and now you
try as normal user or so.
Markus
