[GRASS-user] Question about least cost path
M S mseibel at gmail.com
Mon Feb 22 15:35:02 EST 2010
Is the path terminating in local minimums?  It is my understanding
that r.drain overcomes pits/sinks in a DEM by traversing lowest
locations until goes off map.
Mark
On Sun, Feb 21, 2010 at 6:44 AM, johannnes83 <j.m.signer at gmail.com> wrote:
> Dear All,
> I am using least cost path to model migration of wildlife through the
> landscape. In my understanding from what I have read on this list and in the
> grass manual I do the following steps:
> 1.) r.walk or r.cost for the cost distance.
> 2.) r.drain where the starting point is the end point from the cost
> distance.
> However, how do I overcome a local minimum (valleys) with r.drain?
> Any hints would be appreciated.
> Thanks Johannes
> View this message in context: http://n2.nabble.com/Question-about-least-cost-path-tp4606448p4606448.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
