[GRASS-user] [r.resample] null values for min and max range of data
	values
    baobazz
    baobazz at hotmail.fr
    Thu Feb 25 03:21:46 EST 2010
Hello,
Let me introduce myself: I'm french and new to the GRASS Universe
I'm really amazed by all its possibilities and hope I will have the
knowledge take the most of them..
I've got some problems with resampling an image.
Initially, I wanted to vectorize an image
After having imported it, I tried to thin it through the r.thin command.
But the image produced being too big, it caused errors on my computer.
To solve my problem, I decided to reduce my location resolution: res=2, then
that of my raster with r.resample...
The problem is that my resampled raster output is empty.
When typing r.info raster.resampled, I get:
r.info raster.resampled2
 | Layer:    raster.resampled             Date: Tue Feb 16 15:10:35 2010
 | Mapset:   PERMANENT                      |
 | DataBase: D:\GRASS Database
 | Title:     ( raster )
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 0
 |   Data Type:    CELL
 |   Rows:         500
 |   Columns:      500
 |   Total Cells:  250000
 |        Projection: Lambert Conformal Conic
 |            N:    6133000    S:    6132000   Res:     2
 |            E:    1235000    W:    1234000   Res:     2
 |   Range of data:    min = NULL  max = NULL
 |   Data Description:
 |    generated by r.in.gdal
 |   Comments:
 |    r.in.gdal input="C:/tests/GRASS/rasterToVect/BDP_08_1234_6134_010_L9\
 |    3.tif" output="raster"
(Mon Feb 22 14:28:09 2010) Command finished (0 sec)
What is strange is the null range of data...
The r.info for my raster input, not resampled is:
r.info raster6133_2
 | Layer:    raster6133_2                   Date: Fri Feb 19 16:35:13 2010
 | Mapset:   PERMANENT                      |
 | Title:     ( raster6133_2 )
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 1
 |   Data Type:    CELL
 |   Rows:         10000
 |   Columns:      10000
 |   Total Cells:  100000000
 |            N:    6133000    S:    6132000   Res:   0.1
 |            E:    1235000    W:    1234000   Res:   0.1
 |   Range of data:    min = 0  max = 1
 |   Data Description:
 |   Comments:
 |    r.in.gdal input="C:/tests/vectorisation/BDParcellaire/BDP_08_1234_61\
 |    33_010_L93.tif" output="raster6133_2"
Why is the range of data null?
How to solve that problem?
Thanks in advance!
Mat'
View this message in context: http://n2.nabble.com/r-resample-null-values-for-min-and-max-range-of-data-values-tp4631171p4631171.html
Sent from the Grass - Users mailing list archive at Nabble.com.
