[GRASS-user] Retrieving Subsets names from gdalinfo with Python
Νίκος
Νίκος
Thu Feb 25 12:41:52 EST 2010
On Thu, 2010-02-25 at 17:26 +0000, Jose Gomez-Dans wrote:
> Hi,
> On 25 February 2010 16:32, Nikos Dumakis <nikosdu1980 at gmail.com>
> wrote:
> I'm doing/trying a Python Script to retrieve MODIS subset
> names using GDALinfo.
> 1- is there any Script already developed in GRASS- python to
> retrieve subset names using GDALINFO
> 2- If not, how can I store in a variable the result from
> GDALinfo?
> It's quite easy to do this with the GDAL python bindings (presumably
> installed if you bothered to install gdalinfo). GetSubDatasets()
> returns a list where each element is the dataset name and the
> description
> hands on example ;)
> In [1]: from osgeo import gdal
> In [2]: g=gdal.Open("MOD09GA.A2009270.h21v10.005.2009272135254.hdf")
> In [3]: g.GetSubDatasets()
> Out[3]:
> [('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:num_observations_1km',
> '[1200x1200] num_observations_1km MODIS_Grid_1km_2D (8-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:state_1km_1',
> '[1200x1200] state_1km_1 MODIS_Grid_1km_2D (16-bit unsigned
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:SensorZenith_1',
> '[1200x1200] SensorZenith_1 MODIS_Grid_1km_2D (16-bit integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:SensorAzimuth_1',
> '[1200x1200] SensorAzimuth_1 MODIS_Grid_1km_2D (16-bit integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:Range_1',
> '[1200x1200] Range_1 MODIS_Grid_1km_2D (16-bit unsigned integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:SolarZenith_1',
> '[1200x1200] SolarZenith_1 MODIS_Grid_1km_2D (16-bit integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:SolarAzimuth_1',
> '[1200x1200] SolarAzimuth_1 MODIS_Grid_1km_2D (16-bit integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:gflags_1',
> '[1200x1200] gflags_1 MODIS_Grid_1km_2D (8-bit unsigned integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:orbit_pnt_1',
> '[1200x1200] orbit_pnt_1 MODIS_Grid_1km_2D (8-bit integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:num_observations_500m',
> '[2400x2400] num_observations_500m MODIS_Grid_500m_2D (8-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:sur_refl_b01_1',
> '[2400x2400] sur_refl_b01_1 MODIS_Grid_500m_2D (16-bit integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:sur_refl_b02_1',
> '[2400x2400] sur_refl_b02_1 MODIS_Grid_500m_2D (16-bit integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:sur_refl_b03_1',
> '[2400x2400] sur_refl_b03_1 MODIS_Grid_500m_2D (16-bit integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:sur_refl_b04_1',
> '[2400x2400] sur_refl_b04_1 MODIS_Grid_500m_2D (16-bit integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:sur_refl_b05_1',
> '[2400x2400] sur_refl_b05_1 MODIS_Grid_500m_2D (16-bit integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:sur_refl_b06_1',
> '[2400x2400] sur_refl_b06_1 MODIS_Grid_500m_2D (16-bit integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:sur_refl_b07_1',
> '[2400x2400] sur_refl_b07_1 MODIS_Grid_500m_2D (16-bit integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:QC_500m_1',
> '[2400x2400] QC_500m_1 MODIS_Grid_500m_2D (32-bit unsigned
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:obscov_500m_1',
> '[2400x2400] obscov_500m_1 MODIS_Grid_500m_2D (8-bit integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:iobs_res_1',
> '[2400x2400] iobs_res_1 MODIS_Grid_500m_2D (8-bit unsigned
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:q_scan_1',
> '[2400x2400] q_scan_1 MODIS_Grid_500m_2D (8-bit unsigned integer)')
(You are too fast Jose ;-)
I have also something in bash (just in case...).
Regards, Nikos Al.
