[GRASS-user] Retrieving Subsets names from gdalinfo with Python
Νίκος
Νίκος
Thu Feb 25 13:52:40 EST 2010
On Thu, 2010-02-25 at 18:40 +0000, Nikos Dumakis wrote:
> Thanks but I don't have that module installed :(
> What I mean was to run gdalinfo directly and have a variable to store
> the result from gdalinfo...
> By the way, where can I find that python module (osgeo)?
Hmmm, as far as I know, you don't need to install anything extra if you
already have/use GDAL tools _and_ Python in your system.
Information (that should be) of your interest:
http://wiki.osgeo.org/wiki/OSGeo_Python_Library
http://trac.osgeo.org/gdal/wiki/GdalOgrInPython
http://grass.osgeo.org/wiki/GRASS_and_Python
Cheers, Nikos Al.
On 25 February 2010 16:32, Nikos Dumakis <nikosdu1980 at gmail.com>:
> > I'm doing/trying a Python Script to retrieve MODIS
> subset
> > names using GDALinfo.
> > 1- is there any Script already developed in GRASS-
> python to
> > retrieve subset names using GDALINFO
> > 2- If not, how can I store in a variable the result
> from
> > GDALinfo?
On Thu, 2010-02-25 at 17:26 +0000, Jose Gomez-Dans wrote:
> > Hi,
> > It's quite easy to do this with the GDAL python bindings
> (presumably
> > installed if you bothered to install gdalinfo).
> GetSubDatasets()
> > returns a list where each element is the dataset name and
> the
> > description
> > hands on example ;)
> > In [1]: from osgeo import gdal
> > In [2]:
> g=gdal.Open("MOD09GA.A2009270.h21v10.005.2009272135254.hdf")
> > In [3]: g.GetSubDatasets()
> > Out[3]:
> [('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:num_observations_1km',
> > '[1200x1200] num_observations_1km MODIS_Grid_1km_2D (8-bit
> > integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:state_1km_1',
> > '[1200x1200] state_1km_1 MODIS_Grid_1km_2D (16-bit
> unsigned
> > integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:SensorZenith_1',
> > '[1200x1200] SensorZenith_1 MODIS_Grid_1km_2D (16-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:SensorAzimuth_1',
> > '[1200x1200] SensorAzimuth_1 MODIS_Grid_1km_2D (16-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:Range_1',
> > '[1200x1200] Range_1 MODIS_Grid_1km_2D (16-bit unsigned
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:SolarZenith_1',
> > '[1200x1200] SolarZenith_1 MODIS_Grid_1km_2D (16-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:SolarAzimuth_1',
> > '[1200x1200] SolarAzimuth_1 MODIS_Grid_1km_2D (16-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:gflags_1',
> > '[1200x1200] gflags_1 MODIS_Grid_1km_2D (8-bit unsigned
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_1km_2D:orbit_pnt_1',
> > '[1200x1200] orbit_pnt_1 MODIS_Grid_1km_2D (8-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:num_observations_500m',
> > '[2400x2400] num_observations_500m MODIS_Grid_500m_2D
> (8-bit
> > integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:sur_refl_b01_1',
> > '[2400x2400] sur_refl_b01_1 MODIS_Grid_500m_2D (16-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:sur_refl_b02_1',
> > '[2400x2400] sur_refl_b02_1 MODIS_Grid_500m_2D (16-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:sur_refl_b03_1',
> > '[2400x2400] sur_refl_b03_1 MODIS_Grid_500m_2D (16-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:sur_refl_b04_1',
> > '[2400x2400] sur_refl_b04_1 MODIS_Grid_500m_2D (16-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:sur_refl_b05_1',
> > '[2400x2400] sur_refl_b05_1 MODIS_Grid_500m_2D (16-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:sur_refl_b06_1',
> > '[2400x2400] sur_refl_b06_1 MODIS_Grid_500m_2D (16-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:sur_refl_b07_1',
> > '[2400x2400] sur_refl_b07_1 MODIS_Grid_500m_2D (16-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:QC_500m_1',
> > '[2400x2400] QC_500m_1 MODIS_Grid_500m_2D (32-bit unsigned
> > integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:obscov_500m_1',
> > '[2400x2400] obscov_500m_1 MODIS_Grid_500m_2D (8-bit
> integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:iobs_res_1',
> > '[2400x2400] iobs_res_1 MODIS_Grid_500m_2D (8-bit unsigned
> > integer)'),
> ('HDF4_EOS:EOS_GRID:"MOD09GA.A2009270.h21v10.005.2009272135254.hdf":MODIS_Grid_500m_2D:q_scan_1',
> > '[2400x2400] q_scan_1 MODIS_Grid_500m_2D (8-bit unsigned
> integer)')
2010/2/25 Νίκος Αλεξανδρής <nikos.alexandris at felis.uni-freiburg.de>
> (You are too fast Jose ;-)
> I have also something in bash (just in case...).
> Regards, Nikos Al.
