[GRASS-user] Problem with r.xtent installation
    Simone Bonzano
    simonebonzano at googlemail.com
    Fri Feb 26 12:01:26 EST 2010
Good Morning,
I have a problem trying to install r.xtent addon on GRASS GIS 6.4.0rc5 on
Kubuntu 9.10 64bit installed through UbuntuGIS unstable repository (grass and
grass-dev).
I tried through GEM but either 'gem64' or 'gem' return to "command not found";
GEM appear in my computer in /usr/lib/grass64/etc/gem but only with the
subdirectory /skeleton.
I have tried to compile downloading by svn r.xtent in /usr/lib/grass64 with
the command "sudo make MODULE_TOPDIR=/usr/lib/grass64" but it usually fails
because several library are not present in the new made folder /build/buildd.
Can someone help me?
Best
Simone
