[GRASS-user] d.out.file fails to create PDF output on OSX
William Kyngesburye woklist at kyngchaos.com
Sun Jan 3 12:34:43 EST 2010
hmm, the DYLD_LIBRARY_PATH setup that GRASS uses should let it find libpixman inside GRASS.  Maybe the reference to a specific version is causing trouble.  Try this (all one line):
sudo ln -s libpixman-1.dylib /Applications/GRASS-6.4.app/Contents/MacOS/lib/libpixman-1.0.dylib
On Jan 3, 2010, at 10:05 AM, Christian Kaiser wrote:
> Hi,
> I am having problems using d.out.file when using the Cairo driver with GRASS 6.4RC5 on Mac OS X Snow Leopard. It gives me the following output:
> GRASS 6.4.0svn (Suisse):~ > d.out.file -cr output=/Temp/test.pdf format=pdf
> Saving display from Monitor: [x0] to </Temp/test.pdf.pdf>.
> Image size [977 x 668]
> dyld: Library not loaded: /Users/Shared/src/cairo/build/snow/intel/lib/libpixman-1.0.dylib
>  Referenced from: /Applications/GRASS-6.4.app/Contents/MacOS/lib/libcairo.2.dylib
>  Reason: image not found
> WARNING: No socket to connect to for monitor <cairo>.
> Forcing a smooth legend: too many categories for current window height
> 100%
> WARNING: No such monitor as <cairo>
> Screen export complete. (writing the file may take a small amount of time)
> Image crop [636 x 443]
> Done.
> It seems to me that there is a problem with the libpixman-1.0.dylib located in /Users/Shared/src/...
> I am using the precompiled GRASS 6.4 RC5-3 for Snow Leopard from Knygchaos.
> I don't know whether there is a link with ticket #656 which describes a related problem and that was due to an installer problem.
> Thank you for an indication what is wrong.
> Christian Kaiser
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
