[GRASS-user] GRASS Scripting questions
António Rocha
antonio.rocha at deimos.com.pt
Mon Jan 4 12:04:10 EST 2010
After a few emails exchanged with Glynn I finally solved this:
*export GRASS_OVERWRITE=1
r.mapcalc "$GIS_OPT_CONTADOR= float(0)"
tmp=tmp.dwe.ndviserie.$$
IFS=,
for opt in $GIS_OPT_INPUT; do
r.mapcalc "$tmp = $opt + $GIS_OPT_CONTADOR"
g.rename rast=$tmp,$GIS_OPT_CONTADOR
done
r.info -r $GIS_OPT_CONTADOR*
To be noted:
- export is used in order to overwrite files
- I use a TMP that is defined by *tmp=tmp.dwe.ndviserie.$$
*- IFS is essential in order to define , as a separator symbol.
One question, Glynn: Where can I get more information about Bash script
expression such as "export"?
Thanks
Antonio
António Rocha wrote:
> Hey
> I have tried Glynn's solution like this:
> r.mapcalc "$GIS_OPT_COUNTER= float(0)"
> tmp=tmp.myscript.$$
> r.mapcalc "$tmp = $opt + $GIS_OPT_COUNTER"
> g.rename rast=$tmp,$GIS_OPT_COUNTER
> done
> And I got
> */syntax error, unexpected ',', expecting $end
> Parse error
> raster <tmp.myscript.724> not found/*
> I changed myscript to r.ndviserie/* */(myscript filename) and i got this:
> /*syntax error, unexpected ',', expecting $end
> Parse error
> raster <tmp.dwe.ndviserie.3692> not found*/
> It seems that he is not recognizing tmp as a file where to store an
> image.
> yesterday I found a reference of initializing TMP files with a
> "r_fillnulls_". I try to find this function, or any reference to this,
> but nothing was found. What is this?
> Thanks Glynn and everyone else
> Antonio
>>> Greetings Achim
>>> You are absolutely right. I made a mistake copying the expression.
>>> Here it goes:
>>> #itinialization of counter1
>>> r.mapcalc $GIS_OPT_COUNTER1= "float (0)"
>>> The cycle:
>>> IFS=,
>>> r.mapcalc $GIS_OPT_COUNTER= "$opt+$GIS_OPT_COUNTER"
>>> done
>> Don't use the same map as both input and output. Instead:
>> tmp=tmp.myscript.$$
>> g.rename --o rast=$tmp,$GIS_OPT_COUNTER
>> done
>> Although for this specific task (adding a list of maps), use
>> "r.series ... method=sum".
> __________ Information from ESET NOD32 Antivirus, version of virus
> signature database 4698 (20091218) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
> signature database 4743 (20100104) __________
> http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4743 (20100104) __________
http://www.eset.com
