[GRASS-user] Uploading bounding box of vectors to database?
Christian Kaiser
Christian.Kaiser at unil.ch
Wed Jan 6 12:25:26 EST 2010
Thank you for the hint. I was not aware of the -r switch. I think I can create a small script doing what I want using the v.db.select -r. Thanks again to everybody who helped!
Christian
On 5 janv. 2010, at 23:14, Martin Landa wrote:
> Hi,
> 2010/1/5 Christian Kaiser <Christian.Kaiser at unil.ch>:
>> Thank you for your answer. It seems to me that v.info -g prints out the
>> region for all the map. What I would need is the bounding box of EACH
>> geometry (area for instance) in the map, and not the map as a whole.
>> Probably my question was not clear... ;-)
> v.db.select -r
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
