[GRASS-user] v.out.ogr kml error
henry83
heamaya at gmail.com
Wed Jan 6 19:06:25 EST 2010
Hi everyone! I have created a contour map from a SRTM elevation model, after
filling nulls, filling depressions and creating the contour map I need to
export it to kml.
I have used the following command
v.out.ogr input=srtm_contours dsn=/home/henry/srtm_contours.kml format=KML
output:
WARNING: Vector map <srtm_contours> is 3D. Use format specific
layer creation options (parameter 'lco') to export in 3D rather
than 2D (default)
Exporting 360384 points/lines...
100%
360384 features written
The thing is that if I try to open the generated file with google earth it
gets hanged...
Arterwards I tried to add this to the command:
dsco="AltitudeMode=absolute"
Neither I've gotten a good result. Does this problem have to be with "lco"
parameter? Because I really don't know what to put in that parameter, and I
really need to get the contours over google earth.
Any help will be appreciated. Thanks in advance.
View this message in context: http://n2.nabble.com/v-out-ogr-kml-error-tp4264064p4264064.html
Sent from the Grass - Users mailing list archive at Nabble.com.
