[GRASS-user] v.in.ascii problems when creating 3d vector GRASS 6.5
Hamish hamish_b at yahoo.com
Wed Jan 6 21:57:02 EST 2010
stephen sefick wrote:
> > I am trying to import a 3-d vector that will eventually be
> > interpolated with v.surf.idw.
John:
> Use this before v.in.ascii to connect the database:
> db.connect driver=dbf database=$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ -p
you will want to use 'single' quotes around that database= string
to stop the shell from trying to expand the $VARIABLES.
> To add to that, if there is a space between the values, fs=space
> (not " ").
actually it doesn't mind, both ways work.
Hamish
