[GRASS-user] v.out.ogr kml error
    henry83
    heamaya at gmail.com
    Thu Jan  7 20:39:09 EST 2010
Thank you Leonidas I will try to do it that way and hope it works, but before
that I would like to get the contours as less dispersed polylines. As you
can see in the image I have attached contours doesn't look as smoth lines as
I would like, do you know how to improve this? Thank you.
http://n2.nabble.com/file/n4269927/contours.png
henry83 wrote:
> Hi everyone! I have created a contour map from a SRTM elevation model,
> after filling nulls, filling depressions and creating the contour map I
> need to export it to kml.
> I have used the following command
> v.out.ogr input=srtm_contours dsn=/home/henry/srtm_contours.kml format=KML
> output:
> WARNING: Vector map <srtm_contours> is 3D. Use format specific
>          layer creation options (parameter 'lco') to export in 3D rather
>          than 2D (default)
> Exporting 360384 points/lines...
>  100%
> 360384 features written
> The thing is that if I try to open the generated file with google earth it
> gets hanged...
> Arterwards I tried to add this to the command:
> dsco="AltitudeMode=absolute"
> Neither I've gotten a good result. Does this problem have to be with "lco"
> parameter? Because I really don't know what to put in that parameter, and
> I really need to get the contours over google earth.
> Any help will be appreciated. Thanks in advance.
View this message in context: http://n2.nabble.com/v-out-ogr-kml-error-tp4264064p4269927.html
Sent from the Grass - Users mailing list archive at Nabble.com.
