[GRASS-user] d.out.file fails to create PDF output on OSX
Christian Kaiser Christian.Kaiser at unil.ch
Fri Jan 8 11:36:53 EST 2010
William,
No, I didn't see your response. Sorry for this. I didn't find them in my mails, and my research in the archive was not successful.
Anyway, thank you very much for the quick answer. Everything is ok now. It did solve the problem.
I could have thought of this solution by myself... Sometimes brain is just switched off...
BTW, thank you for the great work you are doing for the community. And all the others too, of course! It is a real pleasure working with GRASS.
Regards,
Christian Kaiser
On 8 janv. 2010, at 17:11, William Kyngesburye wrote:
> Did you see my previous response to this?  try this, then try running d.out.file:
> sudo ln -s libpixman-1.dylib /Applications/GRASS-6.4.app/Contents/MacOS/lib/libpixman-1.0.dylib
> On Jan 8, 2010, at 9:37 AM, Christian Kaiser wrote:
>> Hi everybody,
>> Probably a problem not linked to GRASS itself, but to packaging the Mac OS X binary...
>> I am having troubles using d.out.file when using the Cairo driver with GRASS 6.4RC5 on Mac OS X Snow Leopard. It gives me the following output:
>> GRASS 6.4.0svn (Suisse):~ > d.out.file -cr output=/Temp/test.pdf format=pdf
>> Saving display from Monitor: [x0] to </Temp/test.pdf.pdf>.
>> Image size [977 x 668]
>> dyld: Library not loaded: /Users/Shared/src/cairo/build/snow/intel/lib/libpixman-1.0.dylib
>> Referenced from: /Applications/GRASS-6.4.app/Contents/MacOS/lib/libcairo.2.dylib
>> Reason: image not found
>> WARNING: No socket to connect to for monitor <cairo>.
>> Forcing a smooth legend: too many categories for current window height
>> 100%
>> WARNING: No such monitor as <cairo>
>> Screen export complete. (writing the file may take a small amount of time)
>> Image crop [636 x 443]
>> Done.
>> It seems to me that there is a problem with the libpixman-1.0.dylib located in /Users/Shared/src/...
>> I am using the precompiled GRASS 6.4 RC5-3 for Snow Leopard from Knygchaos.
>> I don't know whether there is a link with ticket #656 which describes a related problem and that was due to an installer problem.
>> Thank you for an indication what is wrong.
>> Kind regards,
>> Christian Kaiser
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
> - the wisdom of Tarzan
