[GRASS-user] Searching Docs about 3D geological modelisation
Dylan Beaudette dylan.beaudette at gmail.com
Mon Jan 11 10:14:20 EST 2010
Hi Thomas,
I am pretty sure that the program (maybe not the source code) are in
the public domain.
I'll contact the author, and post back.
Cheers,
Dylan
On Mon, Jan 11, 2010 at 6:56 AM, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
> Dylan,
> Can you tell me how to obtain TPROGS? Is it only available commercially?
> Thanks,
> Tom
> Dylan Beaudette wrote:
>> Two more ideas:
>> 1. conditional simulation, based on a 3D variogram model
>> 2. transition probability-based interpolation of categories
>> Check out gstat for the conditional simulation, and TPROGS for the
>> transition probability. If anything is interested, I have done some
>> programming to connect GRASS and TPROGS.
>> Cheers!
>> Dylan
>> On Fri, Jan 8, 2010 at 1:24 PM, Benjamin Ducke
>> <benjamin.ducke at oxfordarch.co.uk> wrote:
>>> Woohoo, this forum is always a treasure trove
>>> of good advice. I had not idea SGemS existed!
>>> The Voronoi idea is also good, I am just not sure
>>> that the 3D Voronoi diagram is quite what one
>>> would instinctively think it is.
>>> http://en.wikipedia.org/wiki/Voronoi_diagram
>>> says: "In general a cross section of a 3D Voronoi
>>> tessellation is not a 2D Voronoi tessellation itself."
>>> Need to look into that.
>>> I don't have much practical experience
>>> with Bayes models, so can't really comment on
>>> that.
>>> Cheers,
>>> Ben
>>> Christian Kaiser wrote:
>>>> It seems to me that this is a 3D interpolation problem with categorical
>>>> variables.
>>>> Maybe the Bayesian Maximum Entropy approach could help. There are some
>>>> interesting publications around also for geology and soil sciences, and they
>>>> can deal with categorical data as well. Look for example here:
>>>> http://www.enge.ucl.ac.be/staff/curr/Bogaert/biblioBME/BMEbibsubject.html#Soil%20Science
>>>> Or maybe you can have a look at SGeMS (http://sgems.sourceforge.net), a
>>>> tool for 3D geostatistics.
>>>> None of them is available through GRASS, but the algorithms are freely
>>>> available (I think open-source, but not verified).
>>>> I am not a geologist, so please forgive if it is not adequate...
>>>> Christian Kaiser
>>>> On 8 janv. 2010, at 11:04, Benjamin Ducke wrote:
>>>>> Rich Shepard wrote:
>>>>>>> material. There is no interpolation algorithm in GRASS currently
>>>>>>> which
>>>>>>> can
>>>>>>> handle that sort of data well.
>>>>>>  So what is needed is a political algorithm. :-)
>>>>> That's actually right: given the presence of n different
>>>>> layer types in the vicinity of an empty voxel, the algorithm
>>>>> would need to decide by some sort of "majority vote"
>>>>> which type to assign to that voxel.
>>>>>>  Kidding aside, I suspect that a fuzzy interpolation algorithm would
>>>>>> solve
>>>>>> the problem.
>>>>> How? You could make the interpolated value depend on a
>>>>> fuzzy set member function, I suppose, but the situation
>>>>> here is actually so well defined that I think a probabilistic
>>>>> approach would be preferable. Since each voxel can only
>>>>> store one value, a second output map could store the
>>>>> classification probability. That may be very useful
>>>>> for visualization (you could show voxels with little
>>>>> probability hazier).
>>>>> Ben
>>>>>> Rich
>>>>>> _______________________________________________
>>>>>> grass-user mailing list
>>>>>> grass-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>>> Benjamin Ducke
>>>>> Geospatial Consultant
>>>>> Oxford Archaeology Digital
>>>>> Janus House
>>>>> Osney Mead
>>>>> OX2 0ES
>>>>> Oxford, U.K.
>>>>> Tel: +44 (0)1865 263 800 (switchboard)
>>>>> Tel: +44 (0)1865 980 758 (direct)
>>>>> Fax :+44 (0)1865 793 496
>>>>> benjamin.ducke at oadigital.net
>>>>> http://oadigital.net
>>>>> Files attached to this email may be in ISO 26300 format (OASIS Open
>>>>> Document Format). If you have difficulty opening them, please visit
>>>>> http://iso26300.info for more information.
>>> Benjamin Ducke
>>> Janus House
>>> Osney Mead
>>> OX2 0ES
>>> Oxford, U.K.
> Thomas E Adams
> National Weather Service
> Ohio River Forecast Center
> 1901 South State Route 134
> Wilmington, OH 45177
> EMAIL:  thomas.adams at noaa.gov
> VOICE:  937-383-0528
> FAX:    937-383-0033
