[GRASS-user] ps.map and line style
Vincent Bain bain at toraval.fr
Tue Jan 12 09:06:49 EST 2010
Hi John,
thanks for the trick, I'll give it a try, though I need two black lines
with /transparency/ in between.
Vincent.
 Le mardi 12 janvier 2010 à 10:10 +0000, John A Stevenson a écrit :
> Vincent Bain wrote:
> > Hello,
> > in a map composition I need to draw contours with two particular
> > linestyles:
> > - a line bedecked with crosses: ----x----x----x----x----
> > - a double line: =====================
> Hi Vincent,
> I have plotted a double line like this:
> vlines my_lines
>     color yellow
>     width 1.5
>     label Chirp lines
>     lpos 4
>     style 000111
> end
> vlines my_lines
>     color black
>     width 3
>     label Chirp lines
>     lpos 4
>     style 000111
> end
> The top entry in the file plots on top in the map.  This gives a black
> dotted line with a yellow middle.  Specifying the same legend position
> recreates the pattern in the legend.
> Later
> John
