[GRASS-user] Displaying Multiple Adjacent Raster Maps
Glynn Clements
glynn at gclements.plus.com
Wed Jan 13 13:32:20 EST 2010
Rich Shepard wrote:
> What I expected to be simple is eluding me.
> Using r.in.gdal I've imported 10m DEM maps for the NE, SE, and SW
> quadrants of Oregon to augment the already imported NW quadrant. Now,
> however, I'm having difficulties displaying all four simultaneously to make
> sure they edge match and cover the entire state. This happens with both the
> GUI and the command line.
> I can display only one at a time. It must be a WIND/region issue that I've
> not correctly defined, and I don't see what I've missed.
> The rows, columns, and total cells for each map are:
> Quadrant Rows Columns Cells
> NW 18724 24657 461677668
> NE 18856 24779 467232824
> SE 18680 24650 460462000
> SW 18732 24662 461968584
> Using the highest pair of rows (37588) and highest pair of columns (49441)
> I set g.region with those totals. The PROJ_UNITS are in feet so I also set
> ewres and nsres to 3.048, but one setting overrides the other, so I elected
> to go with the rows/columns.
> d.rast draws very slowly, and as soon as I repeat the command with a
> different map the first is erased and replaced.
> What is the proper approach to defining a region to accommodate 4 DEM
> quadrants?
g.region rast=rast1,rast2,...
will set the current region to the minimum rectangle containing all of
the rasters.
For display, you should probably set res= to a larger value to speed
things up. There's no point in reading the rasters at a resolution far
higher than can be displayed.
> How do I display them all simultaneously on the monitor?
d.rast -o ...
makes null cells (including those outside of the raster) transparent.
In 7.0, this is the default behaviour (the -n flag makes null cells
opaque).
