[GRASS-user] Obtaining unique nodes from a topology
William Temperley
willtemperley at gmail.com
Fri Jan 15 09:49:24 EST 2010
Ah this is probably what I'm looking for, thanks Achim
Will
2010/1/15 Achim Kisseler <ak7 at jupiter.uni-freiburg.de>
> Hi Will,
> I think it is possible:
> building a network from boundaries with
> v.net
> and then using the report option in v.net
> it is not possible to update the table with these infos, but it is possible
> to save the results in a list, import this to your database and connect
> these infos to the table.
> Achim
> William Temperley schrieb:
>> Hi Achim
>> Thanks - but what I really want is a list of unique nodes (i.e. where
>> three boundaries meet, there would be one node, with an id) and assign this
>> id to the relevant boundaries. Perhaps that isn't possible. It might be
>> easier to do this in PostGIS. I need to be able to run recursive queries in
>> PostGIS to pick up connected boundaries.
>> Cheers
>> Will
>> 2010/1/15 Achim Kisseler <ak7 at jupiter.uni-freiburg.de <mailto:
>> ak7 at jupiter.uni-freiburg.de>>
>> Hi Will,
>> for lines you can use
>> v.to.db -p map=... option=start
>> -p to print your result
>> option=start to get start points
>> option=end to get end points
>> the result looks like
>> cat|x|y|z
>> without -p you can upload the results to the table with:
>> columns=x,y(,z)
>> Hope it helps,
>> Achim
>> Hi all
>> I've used Grass to build a topology out of a polygon shapefile,
>> so far so good.
>> I now need to export it as an arc-node topology (i.e. boundaries
>> with startnode_id, endnode_id) which I will then use in PostGIS.
>> Does anyone know of a way to get the nodes from the topology and
>> attach these attributes to the boundaries?
>> I know I can get the start/end coordinates, but I need the
>> unique nodes and their ids.
>> Thanks
>> Will Temperley
>> grass-user mailing list
>> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100115/2c29b3e5/attachment.html
