[GRASS-user] Python scripting and GRASS
Sun Jan 17 20:19:13 EST 2010
Markus Neteler wrote:
> > Can I use SWIG? Do I have to install it extra, or is there an integrated
> > version?
> SWIG is an extra software which generates extra Python bindings.
> You do not necessarily need it for GRASS-Python programming, it
> depends on the level of integration you want to achieve between your
> model and GRASS.
Also, the current SWIG bindings should be considered "experimental",
and likely to change.
