[GRASS-user] change the cell value of a geotiff
maven apache
apachemaven0 at gmail.com
Wed Jan 20 21:00:27 EST 2010
2010/1/21 Hamish <hamish_b at yahoo.com>
> maven apache wrote:
> > I have a geotiff now, and some cells have a not-expected
> > value, so I want to Interpolation them, and I notice that
> > there is a command named r.fillnull, however the cell to be
> > changed is not null, so I want to :
> > 1) change the special cell value to null
> > 2) use the r.fillnull to Interpolation.
> > The problem is I do not know how to do the step 1 with
> > grass, anyone can do me a favor?
> try r.null.
> Hamish
> Hi;
It seems that the r.null does not work.
1) I use the r.info to get the info of the tiff which I have imported to
grass and I got that:
Hi:
(Thu Jan 21 09:56:46
2010)
r.info map=aaa at PERMANENT
| Layer: aaa at PERMANENT Date: Tue Jan 12 16:02:39
2010 |
| Mapset: PERMANENT Login of Creator:
Administrator |
hdf5loc |
| DataBase:
D:\GrassDataBase |
| Title: ( aaa
| Timestamp:
none |
| Type of Map: raster Number of Categories:
499 |
| Data Type:
FCELL |
| Rows:
720 |
| Columns:
1440 |
| Total Cells:
1036800 |
| Projection:
Latitude-Longitude |
| N: 90N S: 90S Res:
0:15 |
| E: 180E W: 180W Res:
0:15 |
| Range of data: min = -1267650600228229401496703205376.000000 max =
4 |
| Data
Description: |
| generated by
r.in.gdal |
Comments: |
| r.in.gdal input="D:\data\hdf5\aaa.tif"
output="aaa" |
(Thu Jan 21 09:56:47 2010) Command finished (0
sec)
(Thu Jan 21 09:56:50 2010)
2)then I use r.null to set the null value to null: r.null
setnull=-1.26765060022823e+030
3) I use the r.info again to see if it is changed :
r.info -r map=aaa at PERMANENT
min=-1.26765060022823e+030
max=498.5
(Thu Jan 21 09:56:50 2010) Command finished (0
sec)
It seems that the valuse are not changed to null.
I wonder why?
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100121/ffd91c8d/attachment.html
