[GRASS-user] r.patch: GRASS-6.5svn
Rich Shepard
rshepard at appl-ecosys.com
Thu Jan 21 22:06:01 EST 2010
On Thu, 21 Jan 2010, Glynn Clements wrote:
> The error "map [%s] - unable to write row %d" doesn't originate in a
> module, it originates in the library, and invariably indicates that
> write() failed.
> [If you're getting a different error, please post the *exact* error
> message, not a paraphrase.]
Hi Glynn,
I killed the r.patch process 66% through because the warning was issued
and in previous attempts this stopped the map being completely displayed:
GRASS 6.5.svn (Oregon):/usr4/grassbase > MAPS=`g.mlist type=rast sep=,
pat="demCEN,demE,demN,demNE,demNW,demS,demSE,demSW,demW"`
GRASS 6.5.svn (Oregon):/usr4/grassbase > g.region rast=$MAPS
GRASS 6.5.svn (Oregon):/usr4/grassbase > r.patch in=$MAPS out=demOR --o
WARNING: map [demOR] - unable to write row 24578
> This can be caused by many things, including (but not limited to):
> * Exceeding the 2GiB limit on a build without LFS.
Here are the configure options I use with -6.4 and -6.5:
--with-postgres \
--with-sqlite \
--with-cairo \
--with-freetype \
--with-cxx \
--with-geos=usr/bin/geos-config \
--with-python=/usr/bin/python-config \
--with-wxwidgets=/usr/bin/wx-config \
--with-includes=/usr/include/ \
--with-libs=/usr/lib/ \
--enable-largefile
> * Exceeding the 4GiB limit of a FAT filesystem.
No FAT on linux.
> * Exceeding "ulimit -f".
[rshepard at salmo ~]$ ulimit -f
unlimited
> * Exceeding quota.
Quotas not enabled; or at default values.
> * Disk full.
[rshepard at salmo ~]$ df -h /usr4
Filesystem Size Used Avail Use% Mounted on
/dev/hdc3 38G 24G 15G 63% /usr4
> * Hardware error
Perhaps, but no problems elsewhere.
> If you built GRASS from source, apply the attached patch with:
> patch -p0 < write_errno.patch
> from the top-level directory of the GRASS source tree, then re-compile.
> This will cause the underlying OS error to be included in the error
> message.
Here are the results:
GRASS 6.5.svn (Oregon):/usr4/grassbase > MAPS=.mlist type=rast sep=,
GRASS 6.5.svn
WARNING: map [demOR] - unable to write row 24578 (No such file or
directory)
100%
Creating support files for raster map <demOR>
and
GRASS 6.5.svn (Oregon):/usr4/grassbase > g.list rast
raster files available in mapset <PERMANENT>:
demCEN demE demN demNE demNW demOR demS demSE demSW demW
so the file is present. But, ...
GRASS 6.5.svn (Oregon):/usr4/grassbase > d.rast demOR
WARNING: Error reading compressed map <demOR at PERMANENT>, row 0
Segmentation fault
Here's what r.info has to tell about the map:
GRASS 6.5.svn (Oregon):/usr4/grassbase > r.info demOR
| Layer: demOR Date: Thu Jan 21 18:36:57 2010 |
| Mapset: PERMANENT Login of Creator: rshepard |
| DataBase: /usr4/grassbase |
| Title: DEM 10m Central Oregon ( demOR ) |
| Timestamp: none |
| Type of Map: raster Number of Categories: 11231 |
| Data Type: CELL |
| Rows: 53388 |
| Columns: 71949 |
| Total Cells: 3841213212 |
| Projection: Lambert Conformal Conic |
| N: 1737497.65432757 S: -13512.48800518 Res: 32.7978224 |
| E: 2502682.81668463 W: 142938.14294121 Res: 32.79746312 |
| Range of data: min = 0 max = 11231 |
Rich
