[GRASS-user] forcing raster accept only integer >0
Jarosław Jasiewicz
jarekj at amu.edu.pl
Fri Jan 22 02:42:05 EST 2010
Milton Cezar Ribeiro pisze:
> Hi Glynn,
> Thanks for the reply. By the way, where I can have access to
> the list of datatypes for a raster map? I ran on my raster map
> and got datatype=CELL. I was expecting to get byte,float,integer...
> bests
> milton
> 2010/1/22 Glynn Clements <glynn at gclements.plus.com
> <mailto:glynn at gclements.plus.com>>
> Milton Cezar Ribeiro wrote:
> > I am trying to work around with a problem of map size under
> Vista (>2G).
> > I was wondering if I use the command below I will get a raster
> > map with values integer and >=0.
> > r.mapcalc "Dem.new=if(Dem>=0,int(Dem),null())"
> That will produce an integer map with no negative values.
> > As my original map have values positive and negative, as well as
> > it is fload, my question is if are there a way of I force my output
> > map accept only integers>=0. By the way, is there a way
> > of I know if a map is float or integer?
> r.info <http://r.info/>, or "r.info <http://r.info/> -t" if you
> only want the type.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
CELL=integer
FCELL=float
DCELL= double precison
J.
