[GRASS-user] new wxGUI
Jarek Jasiewicz
jarekj at amu.edu.pl
Fri Jan 22 17:56:10 EST 2010
Mohammed Rashad pisze:
> Hi,
> I am planning to develop a DataCatalog or GRASS GIS Manager. Design of
> the gui module is almost finished.
> please view the screens and give me a feedback to continue coding the
> module in wxpython.
> I will start coding after getting response from GRASS community
> otherwise it will be wastage of time.
> So please send your valuable comments on the link specified below
> http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS#Data_Catalog
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Hi
I look more or less your work and I think you shall explain something:
- as I remember you first conception was graphical manager of
Grass-data. that what you presented it is new completely GUI conception
(very interesting) so what you plan. Completely new gui is rather
extensive work I guess.?
- what it you have presented: it are mockups (screens created in some
graphic programs, conception) or something working or almost working?
- second as I can see you use components of existing wx-gui. what is
will be: fork of existing wx-python gui or warper on existing
wx-python-gui? If the first I assume you plan to create alternative to
existing proposition with its own path of development int the future or
create warper which will be change with its base. It is important for
you. If it is warper you shall contact with wxgui developers to
synchronize your work (if they accept it).
- conception of integrated one gui looks interesting alternative. But
there are some ides which seems be difficult to implement, for example
browsing in tabs with possibilities of change mapsets and location
on-the-fly. So I assume your proposition will allow to browse maps from
different locations and mapsets in the same session. Did you
implemented it or it is only idea?
So first try to explain this and share your code, than we can discuss
regards
Jarek
