[GRASS-user] Re: Error with NVIZ Compiling 6.4SVN in Linux
Markus Neteler
neteler at osgeo.org
Mon Jan 25 19:54:16 EST 2010
2010/1/25 António Rocha <antonio.rocha at deimos.com.pt>:
> Ok I have added the --with-python=/usr/bin/python2.6-config
> and I still got errors in NVIZ compilation and it's not available
> GRASS GIS compilation log
> Started compilation: Mon Jan 25 14:54:21 WET 2010
> Errors in:
> /home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/lib/nviz
> /home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/gui/wxpython/nviz
> /home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/visualization/nviz
> /home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/visualization/nviz2/cmd
The last line of the log indicates what to do :)
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
If that's unclear please suggest a better wording...
Markus
