On Thu, 28 Jan 2010, Markus Neteler wrote: > If you add -a to g.region, you obtain the desired resolution by > (automatically) a slightly enlarged region which make the pixels fit into > it properly. Markus, Thank you. I'm still learning about the -a option and when to use it. Perhaps this is why some output maps fail. Rich
