[GRASS-user] r.mapcalc question
Achim Kisseler
ak7 at jupiter.uni-freiburg.de
Thu Jan 28 08:13:02 EST 2010
Hello grass-users,
I have a problem running a r.mapcalc procedure:
given two maps
dir_x,
dir_y
with 0,1,-1 entries
I want to run:
r.mapcalc "the_map=if(isnull(the_map),the_map[dir_x,dir_y],null())"
in order to make a r.water.outlet on many many areas at the same time.
The error I get is:
syntax error, unexpected NAME, expecting INTEGER or '-'
why does dir_x/dir_y does not return an integer here? Using int(dir_x)
also does not work.
Until now I use a r.mapcalc command with many "if", checking the
direction of every pixel every time. But this is quite slow.
Achim
