[GRASS-user] Max length of sql_query in v.extract
Markus Neteler neteler at osgeo.org
Thu Jan 28 08:57:09 EST 2010
On Thu, Jan 28, 2010 at 1:34 PM, Luigi Ponti <lponti at infinito.it> wrote:
> On 28/01/2010 00:45, Markus Neteler wrote:
>> On Wed, Jan 27, 2010 at 8:35 PM, Luigi Ponti <lponti at infinito.it> wrote:
>>> Hello,
>>> Is there a length limit to a "where" sql statement fed to v.extract?
>>> I am getting an
>>> Error in db_open_select_cursor()
>>> in the middle of a very long query.
>> Could you please try to analyse with
>>  g.gisenv set=DEBUG=3
>> to identify when it gets lost? And perhaps provide an example
>> based on the Spearfish or North Carolina data sets?
> Version: WinGRASS-6.4.SVN-r40650-1 (installed in C:\GRASS-64-SVN i.e. no
> spaces in path; OS Windows 7)
> Dataset: North Caroline dataset
> Mapset: user1
> vector: census_wake2000 (this actually resides in PERMANENT)
> Working on the "Cmd >" input box of the wxGUI. I have chosen a case
> analogous to that where I encountered the error, i.e. a DBF Character field
> containing 105 different numeric codes (e.g. 050100) one per record:
> (note that you can find full debug output in a text file available at the
> following link:
> https://docs.google.com/leaf?id=0B0EpsfMZ-IZYOTJiYWVmNjUtNGYzMC00NDM5LWI1NDYtZTMyNzg3M2NjOThk&sort=name&layout=list&num=50
> I thought 20,000+ lines was too much for the mailing list but please advice
> if had better taken a different course of action.)
> ### START GRASS CMD HISTORY ###
>   (Thu Jan 28 12:12:34 2010) Command finished (0 sec)
>      (Thu Jan 28 12:12:43 2010)
>         v.extract input=census_wake2000 output=census_extract_all_trt2000
> where=
[... very long WHERE suppressed...]
(TRT2000='050100')or(TRT2000='050300')or(TRT2000='050400')or(TRT2000='050500')or(TRT2000='050600')or(TRT2000='050700')or(TRT2000='050800')or(TRT2000='050900')or(TRT2000='051000')or(TRT2000='051100')or(TRT2000='051200')or(TRT2000='051400')or(TRT2000='051501')or(TRT2000='051502')or(TRT2000='051600')or(TRT2000='051700')or(TRT2000='051800')or(TRT2000='051900')or(TRT2000='052001')or(TRT2000='052002')or(TRT2000='052101')or(TRT2000='052102')or(TRT2000='052201')or(TRT2000='052202')or(TRT2000='052301')or(TRT2000='052302')or(TRT2000='052401')or(TRT2000='052402')or(TRT2000='052404')or(TRT2000='052405')or(TRT2000='052501')or(TRT2000='052503')or(TRT2000='052504')or(TRT2000='052601')or(TRT2000='052602')or(TRT2000='052603')or(TRT2000='052701')or(TRT2000='052703')or(TRT2000='052704')or(TRT2000='052705')or(TRT2000='052801')or(TRT2000='052802')or(TRT2000='052803')or(TRT2000='052804')or(TRT2000='052805')or(TRT2000='052900')or(TRT2000='053001')or(TRT2000='053002')or(TRT2000='053101')or(TRT2000='053103')or(TRT2000='053104')or(TRT2000='053200')or(TRT2000='053402')or(TRT2000='053403')or(TRT2000='053404')or(TRT2000='053405')or(TRT2000='053406')or(TRT2000='053407')or(TRT2000='053501')or(TRT2000='053505')or(TRT2000='053506')or(TRT2000='053507')or(TRT2000='053508')or(TRT2000='053509')or(TRT2000='053510')or(TRT2000='053512')or(TRT2000='053513')or(TRT2000='053514')or(TRT2000='053515')or(TRT2000='053600')or(TRT2000='053703')or(TRT2000='053706')or(TRT2000='053707')or(TRT2000='053709')or(TRT2000='053710')or(TRT2000='053711')or(TRT2000='053712')or(TRT2000='053713')or(TRT2000='053714')or(TRT2000='053715')or(TRT2000='053716')or(TRT2000='053801')or(TRT2000='053802')or(TRT2000='053900')or(TRT2000='054001')or(TRT2000='054003')or(TRT2000='054004')or(TRT2000='054006')or(TRT2000='054007')or(TRT2000='054008')or(TRT2000='054009')or(TRT2000='054010')or(TRT2000='054102')or(TRT2000='054104')or(TRT2000='054105')or(TRT2000='054106')or(TRT2000='054107')or(TRT2000='054108')or(TRT2000='054109')or(TRT2000='054201')or(TRT2000='054202')or(TRT2000='054301')or(TRT2000='054302')or(TRT2000='054401')or(TRT2000='054402')
> D3/3: Mapset = PERMANENT
> D1/3: Vect_open_old(): name = census_wake2000 mapset=
> PERMANENT update = 0
> D1/3: Vect_set_thresh(): thresh = 0.000000
> D3/3: db_select_int()
> D3/3:   SQL: SELECT cat FROM census_wake2000 WHERE (TRT2000=
... first part of very long statement...
> '053101')or(TRT
> DBMI-DBF driver error:
> SQL parser error: syntax error, unexpected $end processing
This looks suspicious:
lib/dbmi/dbmi_client/select.c
int db_select_int(dbDriver * driver, const char *tab, const char *col,
                  const char *where, int **pval)
    int type, more, alloc, count;
    int *val;
    char buf[1024];
    /* allocate */
    alloc = 1000;
    val = (int *)G_malloc(alloc * sizeof(int));
    if (where == NULL || strlen(where) == 0)
        G_snprintf(buf, 1023, "SELECT %s FROM %s", col, tab);
    else
        G_snprintf(buf, 1023, "SELECT %s FROM %s WHERE %s", col, tab, where);
    G_debug(3, "  SQL: %s", buf);
    db_init_string(&stmt);
    db_append_string(&stmt, buf);
I guess that we need to change to dynamic string length allocation here?
The cut string is pretty close to the 1023 chars length.
Markus
