[GRASS-user] r.mapcalc question
Marco Lechner - FOSSGIS e.V. marco.lechner at fossgis.de
Thu Jan 28 09:01:09 EST 2010
Hi Achim,
the neighborhood modifier doesn't seem to accept functions (you also
could try rand(), ...)
Marco
Achim Kisseler schrieb:
> Hello grass-users,
> I have a problem running a r.mapcalc procedure:
> given two maps
> dir_x,
> dir_y
> with 0,1,-1 entries
> I want to run:
> r.mapcalc "the_map=if(isnull(the_map),the_map[dir_x,dir_y],null())"
> in order to make a r.water.outlet on many many areas at the same time.
> The error I get is:
> syntax error, unexpected NAME, expecting INTEGER or '-'
> why does dir_x/dir_y does not return an integer here? Using int(dir_x)
> also does not work.
> Until now I use a r.mapcalc command with many "if", checking the
> direction of every pixel every time. But this is quite slow.
> Achim
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
