[GRASS-user] r.param.scale Incorrect Output
Dylan Beaudette debeaudette at ucdavis.edu
Thu Jan 28 18:50:41 EST 2010
On Thursday 28 January 2010, Rich Shepard wrote:
> On Thu, 28 Jan 2010, Rich Shepard wrote:
> >  I'm stymied trying to get output from r.param.scale that is equivalent
> > to the example on the bottom of the man page.
>    Resetting g.region to the input elevation map without any additional
> options and adding a zmult factor of 5 appears to help. When the specified
> param is 'features' I see what should be ridges and channels, but no peaks
> or pits.
>    Changing the calculated param to either elev or profc yields blank maps
> when I try to display them with d.rast.
>    Suggestions on how to properly apply this module will be very helpful.
> Rich
Are you working with data in a projected coordinate system? Are you x,y and z
coordinates all in the same units. What is the general nature of the terrain
you are looking at? Try adjusting the window size to get generalized
features-- remember that the quantification of terrain is a fractal problem.
Cheers,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
