[GRASS-user] r.stream.basins
Jarosław Jasiewicz
jarekj at amu.edu.pl
Fri Jan 29 02:51:37 EST 2010
stephen sefick pisze:
> Thanks for the response - I moved the values to the closest synthetic
> stream, and it worked without a hitch. Thank you again for your time.
> kindest regards,
> Stephen
> On Thu, Jan 28, 2010 at 6:37 PM, MS <mseibel at gmail.com> wrote:
>> The points need to coincide with a nearby high value accumulation cell.
r.astream.basins allow to make a 'trick' for such situation:
create buffer around GPS points, rasterise it and next use it raster as
stream map. Note that every point shall have its own category
J.
