[GRASS-user] importing rasters
Achim Kisseler
ak7 at jupiter.uni-freiburg.de
Fri Jan 29 08:45:52 EST 2010
can you post the hole command you used?
Achim
ciccpaol at libero.it schrieb:
> Hi everybody,
> I am trying to import a raster file that is in a location "SRTM", into another
> location "LatLong-WGS84" using r.in.gdal
> I am inside the "LatLong-WGS84" location, and once i imported the file i press
> the button to get the raster file added in the manager.
> It seems everything all right, the projections match, but when i try to add
> the raster file, there's anything in the box, that displays only the
> "PERMANENT" directory, empty.
> Many thanks
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
