[GRASS-user] convert to utm projection
Varun Varma varunvarma17 at gmail.com
Thu Jul 8 03:24:09 EDT 2010
Hi Rashad,
You will have to create a new location for the same extent as your data in
lat/long but this time specify the projection for the location as UTM. Then
make this new location and mapset your working grass space. Now use v.proj
OR r.proj to pull in the file from the lat/long location and mapset to the
new location you just created. This should change the projection from
lat/long to UTM.
Cheers,
Varun
On Thu, Jul 8, 2010 at 12:32 PM, Mohammed Rashad <rashadkm at yahoo.com> wrote:
> How to convert a map in lat/long projection to UTM projection using grass
> gis?
> Rashad
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100708/81d7bd62/attachment.html
