[GRASS-user] No Categories found
Sandile Gumede akasandile at gmail.com
Fri Jul 9 02:45:19 EDT 2010
I've tried to sort out the issue of the region resolution. Now when I'm
running v.rast.stats it says:
ERROR: No categories found in raster map
Here is the script I'm running thats giving me that error:
#!/bin/sh
#variable to customize:
# path to GRASS software main directory
GISBASE=/usr/lib/grass64
# path to GRASS database
GISDBASE=$HOME/grassdata/Cape_
Town
LOCATION_NAME=SRTMDEM
MAPSET=PERMANENT
# nothing to change below
MAP=$1
LOCATION=$2
# generate temporal LOCATION:
TEMPDIR=FLOODS
mkdir -p $GISDBASE/$LOCATION_NAME/$MAPSET
# save existing $HOME/.grassrc6
if test -e $HOME/.grassrc6 ; then
mv $HOME/.grassrc6 /tmp/$TEMPDIR.grassrc6
fi
echo "LOCATION_NAME: $LOCATION_NAME" > $HOME/.grassrc6
echo "MAPSET:$MAPSET"                >> $HOME/.grassrc6
echo "DIGITIZER: none"               >> $HOME/.grassrc6
echo "GISDBASE: $GISDBASE"           >> $HOME/.grassrc6
export GISBASE=$GISBASE
# Create a WIND file with minimal information and no projection:
echo "proj: 3
zone:       0
north:      1
south:      0
east:       1
west:       0
cols:       1
rows:       1
e-w resol:  1
n-s resol:  1
top:        1
bottom:     0
cols3:      1
rows3:      1
depths:     1
e-w resol3: 1
n-s resol3: 1
t-b resol:  1
" > $GISDBASE/$LOCATION_NAME/$MAPSET/WIND
# Copy WIND-file to DEFAULT_WIND:
cp $GISDBASE/$LOCATION_NAME/$MAPSET/WIND \
 $GISDBASE/$LOCATION_NAME/$MAPSET/DEFAULT_WIND
echo "name:      Latitude-Longitude
datum:           wgs84
towgs84:         0.000,0.000,0.000
proj:            ll
ellps:             wgs84
"> $GISDBASE/$LOCATION_NAME/$MAPSET/PROJ_INFO
echo "unit: degree
ubits:      degrees
meters:     1.0
"> $GISDBASE/$LOCATION_NAME/$MAPSET/PROJ_UNITS
export PATH=$GISBASE/bin:$GISBASE/scripts:$PATH
export LD_LIBRARY_PATH=$GISBASE/lib:$LD_LIBRARY_PATH
export GIS_LOCK=$$
export GISRC=$HOME/.grassrc6
# this should print GRASS version used:
g.version
# other calculations go here....
# import rainfall data set.
 cd /home/tgumede1/grassdata/Cape_Town
# rainfall data set.
r.in.gdal input=$HOME/grassdata/Cape_Town/TRMMLast1day.tif output=rainfall
# DEM data set.
r.in.gdal input=$HOME/grassdata/Cape_Town/Dem_CF.tif target=SRTMDEM
output=dem
 g.region rast=dem -p
# creating set of maps indicating flow acc, drainage dir, streams
r.watershed --o elevation=dem at PERMANENT drainage=flow_direction basin=catch
accumulation=acc threshold=1 memory=300 stream=str
# convert catch raster to polygon vector
r.to.vect in=catch at PERMANENT out=catchments feature=area
 g.region rast=rainfall -p
# Calculate univariate statistics
v.rast.stats -c vector=catchments at PERMANENT
raster=rainfall at PERMANENTcolpre=precp
Kind Regards
TS Gumede
CSIR, Meraka Institute
072 258 1650
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100709/5507c576/attachment.html
