[GRASS-user] 0 points loaded in v.surf.idw
Chang, Elizabeth Elizabeth.Chang at noblis.org
Tue Jul 13 16:27:13 EDT 2010
I'm trying to import some points from Postgres and convert it into
raster using v.in.ogr and v.surf.idw
v.in.ogr dsn="PG:host=tsf.noblis.org dbname=gis port=5433"
layer=regcm.huss_monavg_2038 output=huss_monavg_2038_395_875
where='timestamp=395.875'
v.surf.idw input=huss_monavg_2038_395_875 column=huss
output=rast_huss_monavg_2038_huss395_875
When I run the v.surf.idw, I get
13936 records selected from table
0 points loaded
ERROR: No data points found
When I try to view it in the map display, I see nothing yet I do see
13936 points which is the right number of points when I do v.info.
v.info huss_monavg_2038_395_875
Layer:           huss_monavg_2038_395_875
 | Mapset:          PERMANENT
 | Database:        /data/grassdata/echang
 | Title:
 | Map scale:       1:1
 | Map format:      native
 | Name of creator: echang
 | Organization:
 | Source date:     Tue Jul 13 15:44:59 2010
 |   Type of Map:  vector (level: 2)
 |   Number of points:       13936           Number of areas:      0
 |   Number of lines:        0               Number of islands:    0
 |   Number of boundaries:   0               Number of faces:      0
 |   Number of centroids:    0               Number of kernels:    0
 |   Map is 3D:              No
 |   Number of dblinks:      1
 |         Projection: Lat/Lon
 |               N:   70:15:29.96521N    S:  19:27:00.387268N
 |               E:  35:43:20.669862W    W: 157:42:49.097902W
 |   Digitization threshold: 0
 |   Comments:
It is a large file so I tried making the region quite small
zone:       0
datum:      nad83
ellipsoid:  grs80
north:      70:15:29.96521N
south:      69N
west:       120W
east:       110W
nsres:      0:15:05.993042
ewres:      0:20
rows:       5
cols:       30
cells:      150
Is there a problem with the resolution? Any ideas?
Thanks,
Elizabeth
Elizabeth Chang
Lead
Noblis
3150 Fairview Park Drive Sourth
Falls Church, VA 22042
703-610-2321 (office)
elizabeth.chang at noblis.org <mailto:elizabeth.chang at noblis.org>
Noblis
For the best of reasons
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100713/2a8b66af/attachment-0001.html
